just finished the install. There was a little more to it than I originally figured. I swapped the entire floor harness out of the same body style truck as mine but from a GMC(extended cab). There were extra wires in this new harness that my old one did not have. Once I got the harness all installed I found my Air bag module would not plug into this new harness. The used GMC harness I bought came with a module, but I had a service air bag system message popping up. After some investigation, this new harness had a passenger seat pressure sensor, and my truck has the switch on the dash to turn the bag on or off. I had to move some wires around in the air bag module plug to match my factory one, and I just pulled out the extras that my truck didn't need. I also had to swap the red connector cap off my harness so it would fit into my factory module. I also had to pull one wire from my harness that went from the air bag module to up under the dash, and install it in my new harness. Both seats have full power, and both seats have functioning factory heaters in them. The only thing that doesn't work, is the memory function. I'm going to call my local dealership and see if they can get that working.
