Lower Control arm bushing recommendations?
Delta.Speed
123
21
I want to replace all the worn-out bushings and ball joints in the front end of my truck while I'm in there installing a lift.
What's the best upgrade for the lower control arm bushings?
Anything available from Kryptonite I'm getting from them, but I don't see that they have a listing for the lower control arm bushings.
They have a listing for the lower ball joints, which I'm getting, but not the bushings, so I was wondering whats the best replacement bushing out there. I would prefer to only have to do this once....
Sent from my SM-S908U1 using Tapatalk
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,330
365
Central OH
What year? I went with Energy Suspension when I replaced mine. Part # 3.3185G
Edit: Looks like that number covers 01-10. Includes the uppers too
Delta.Speed
123
21
Mine is a 2002.
How many miles have you put on yours? Stock height or lifted? Any off-road use?
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,330
365
Central OH
Not a ton of miles, maybe 30k over the last 6 years. It's not a daily, no offroad use, stock height. I still have the uppers from Energy in the box because I had went ahead and replaced the entire control arm, so it only got the lower bushings swapped
Delta.Speed
123
21
Thanks for the info, I will look into them.
4,967
I used polys in the lowers on my old truck and napa ncp (now ncd) part number ball joints. Readily available and will last a very long time. Make sure you use a good amount of the silicone lubricant on the polys and the sleeve so you don’t get squeaking.
Delta.Speed
123
21
Do you remember what brand polys you used?
Delta.Speed
123
21
Anyone have any experience with dmaxstore.com?
I found these complete lower control arms with bushings and kryptonite ball joints already installed.
Seems like a good deal considering I can skip out on paying a shop to press the balljoints and bushings in and out, but I don't know anything about the product quality from this site.
1,755
They are a reputable vendor. But not a sponsor of this site. I've heard most a happy with those control arms
Reactions: countrycorey
