Dad and I were moving cattle. I was pulling our 26 foot gooseneck loaded with cattle with my 01 2500HD 4X4 with the ZF6, and the transmission started to knock. I pulled over and checked it over fluids in the the transmission and transfer case were good. We took the other truck unloaded cattle and went after my old reliable Z-71 and the flatbed trailer. we came back with dads truck unhooked the trailer from max and loaded him on the flatbed then hooked dad's truck up to the stock trailer. It pulled onto the trailer with out a problem and was pulling the loaded trailer easy too. The noise goes away when the clutch pedal is pressed in and resumes when the pedal is released. The noise is in all gears and T-case ranges. I'm hung between the clutch or and input shaft a bearing is going down in the transmission, but it isn't squalling like a bearing. My Dad thinks clutch. I would like to think it isn't since it is only six months old and only has roughly 5,000 miles on it, also it doesn't sound like other failed clutches I've heard anybody has any suggestions? Either way the transmission is coming out. Does any one know what a rebuild kit runs for the ZF6 I know I need a synchronizer for granny? Thanks for the help
