Fass not pumping.
clrussell
pro-procrastinator
Sep 23, 2013
5,910
365
Update on this.
I put my new filters on, primed it, and have been running it off and on in a bucket for two days.
I can’t comment on how much is flows but it’s a solid stream out of the line into the bucket.
clrussell
pro-procrastinator
Sep 23, 2013
5,910
365
Pic
4,970
looks typical from when i would drain my tank with my ad165
question is, how it acts when restriction is there to increase pressure
N2BRK
1,907
233
if it's a 165, then it should fill that 1 gal container in 20 seconds.
13,599
632
You can rig up a tee with a gauge and a ball valve to check pressure and time it filling a gallon jug to approximate flow rate at pressure. Don't close the valve too much, just enough to bring the pressure up to 8-10 psi.
Reactions: LBZ
