So I inherited this truck from a family member and im not well versed in diesel engines/mechanics. Here are the issues im having and then i'll explain what has been done to the truck so far.
1. Wont exceed 2000rpm. From what ive read its in "limp mode". It will drive, and if i ease off the accelerator it will shift and I can get up to 60-65mph. However, it will shift but wont shift to its full potential.
2. When the engine is idle or stopped at a red light, stop sign, etc it will die. If I put it in neutral and milk the throttle though it wont die.
Heres what I know has been done to the truck lately to fix this issue.
-Lift Pump
-Air filter
-Injectors changed
-Batteries changed
-Brand new OEM trans
-Glow plugs changed
If anyone has any suggestions, please. PLEASE let me know. The only conclusion I can come to is the CP3, but I cant see how the truck can run as well as it does if thats the case. Maybe im misunderstanding its complete function?
-Lift Pump
-Air filter
-Injectors changed
-Batteries changed
-Glow plugs changed
