Def pump replaced same issue
mtxcaleb
Apr 18, 2023
29
Watford City North Dakota
Replaced my def pump connector on pump itself had burnt marks harness did not. Same code and limited speed to 65 dealer said they'd warranty pump/heater but suggest I replace harness anyone else have this issue? Tia
juddski88
Freedom Diesel
Jul 1, 2008
4,651
116
Chesterfield, Mass.
A proper diagnosis would have saved some hassle here. Im guessing you didn't check the integrity of the rest of the circuit while you had it apart?
mtxcaleb
Apr 18, 2023
29
I back probed everything but that didn't matter because the pin clamp strength was weak tested the heater circuit on the pump assembly before replacing it and the circuit was open. Replaced harness and everything's normal. More of a question regarding the integrity of GM's electrical lately more so than second quessing my work.
