LLY: coolant tube elbow
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Does anyone know the part number for that little 90* bend in the valley of the engine that connects the factory variable vane turbo hard line to the coolant hard line on the engine? I initially used some regular heater hose but its kinda kinked because its such a sharp bend...
Or any ideas where I could get a pre-formed 90* little piece of heater hose?
thanks
ben
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
I never thought of that simon, good idea. It would have to be a pretty tight bend tho, Id need to buy it pre-bent for sure, if I tried I would definetly kink it..
ben
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
33
Lexington, Ky
I think I need the same hose as you.. the one running from the upper radiator hose to the turbo? Dealer wanted $50 for it. Asume the same thing being an lbz. Does autozone have 90 bend hose? I couldnt tell if it had a bend in it looking at it. Thats what I was worried about, don't feel like dropping 50 for a pin hole leak.
13,605
640
The one going from the upper radiator hose pipe thing to the turbo is just a straight piece of hose. If you buy it from the dealer, you get a package of bulk hose. The 90 degree hose is on the passenger's side of the engine underneath the EGR cooler (if it is still there on your truck).
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
33
Lexington, Ky
That's good to hear, read some people say high temp power steering hose would be the thing to use, 3/8th. Sound correct?
Sent from my PC36100 using Tapatalk
Vrabel
TOYAHOLIC
May 22, 2008
3,434
56
Hewitt, NJ
He was saying using tubing with hose on ends. When I restored me car as a kid I needed to replace all the brake lines. The lines off master have that tight spiral. I used "Kant-Kink" lines, and slowly worked them around neck of bottle. worked great.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
33
Lexington, Ky
Ahh I gotcha
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
ben, fill the tube with sand before you bend it and plug each end and bend gently that will stop it from kinking.
trick for making cooling coils on moonshine stills ;)
13,605
640
I don't think he's looking anymore. This thread is 3 years old.
