I did an EGR delete in my LBZ, normally the EGR cooling line then goes to the Heater core and eventually suck back into the engine.
Here is my question:
I want to install an electric solenoid to only allow coolant flow to the heater core on demand.
If I do this, The outlet (suction) line that comes from the Main coolant line will have a bit of a vacuum which is no issue, the real question is, Will I get a lot pressure in the coolant line that feeds the heater Core/EGR cooler if I plug it with the solenoid in the closed state?
can this pressure be too much that will damage a gasket or something?
P.S I am doing an engine swap in a Humvee so everything is already custom.
Thanks guys!!
Thanks guys!!
