another dual fueler ?
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
got to the point where it says install rubber nipple #9 on fitting...uhh where is it? wasn't in the box i searched 50 times
It doesn't come with one. Hook a line between the brass block and the closest nipple. You might as well bottle test it while your at it because I had a bit of a time getting mine right. There's not by chance a size on the new belt is there. I put mine on wrong and just smoked it off 10 min ago. Got it running though.
RichLMM
699
North Kingstown RI
i know i run the line from the block to the line coming off the fuel rail but i dont leave that other line open do i? i'm kinda confused i'm almost done and this is hanging me up
LBZrcks
Jun 2, 2007
5,297
12
SoCal
There shouldn't be anything coming out of the nipple on the rail since the new fitting blocks it like a race valve would. The last kit I helped put on didn't have a little cap either, even though it mentioned it. We just put some hose on it and bent it over to keep it covered from getting dirty.
RichLMM
699
North Kingstown RI
so the nipple that comes off the rail gets capped off and the hose runs from the gold block to that other nipple that the u shaped rubber line ran to?
LBZrcks
Jun 2, 2007
5,297
12
SoCal
Yes, the hose goes from the gold block to the return line and the rail just needs a little cap/cover.
