  #1
Old 05-18-2011, 12:41 PM
khewell khewell is offline
FNG
Default Fuel pressure regulator
Have to change my fuel pressure regulator.
I know it's stuck way down in there...
About how much time does it take to replace
Thanks
  #2
Old 05-19-2011, 06:47 AM
voltage's Avatar
voltage voltage is offline
voltage
Default
Wll I took my time ya know a few beers so it took me about 2 1/2 hours. LOL.
__________________
04 LB7 CCSB
Quad Stealth II
More to come I hope.
  #3
Old 05-20-2011, 09:21 AM
-Shep-'s Avatar
-Shep- -Shep- is offline
RCLB kind of guy
Default
I gotta do mine. This is the best DIY I've seen. It may be on an LB7, but the procedure is similar on all of them.
http://www.dieselbombers.com/chevrol...fca-k-fpr.html
__________________
'04.5 LLYAllison
EFILive Edge Insight CTS
LBZ Mouthpeice + Volant PowerCore 4" MBRP
4" TC lift-SuperDiesel link & sleeves
Nitto 325/60's-18x12 Pacer 185's
  #4
Old 05-24-2011, 09:40 AM
Micheal Tomac's Avatar
Micheal Tomac Micheal Tomac is offline
been pulling forever
Default
After looking at the DIY article posted, you don't have to remove the t-stat housing and drain the coolant. You just need to remove small hose from the metal x-over pipe that goes from the t-stat housing to the turbo. You will lose a small amount of coolant but a few rags will soak it up. You also don't need to remove the hot pipe from the turbo to intercooler and you don't need to unplug or remove the bail connectors or any wiring on the driver side valve covers.
__________________
2017 Chevy 3500 srw 4x4 Z71 CCSB L5P
2002 Chevy 2500HD 4x4 CCSB LB7
2.5 Turbo, ATS dual CP3's, Crower rods, SoCal stage2 heads, SoCal Cam, SoCal Pushrods, ARP head & main studs, Exergy Injectors, Kennedy lift pumps, FASS 150, EFI Live, PPE Manifolds & up-pipes, Banks Intercooler, ATS Extreme trans, ATS Copilot, ATS 5 Star, ATS flywheel, 5" DHD intake, 5" DHD exhaust, 4" ATS downpipe, Elocker, DHD Spool, SCS Axles, pulling hitch, tierod sleeves, centerlink brace, traction bars, 315x70x17 BFG AT's & some pulling mods = 2014, 2015, 2016 MTTP 2.5 Prostreet Diesel Points Champion, 2009 & 2011 MTTP Hot Diesel Points Champion, 2009 NADM 2.8 Points Champion, 2006 & 2007 DIESEL POWER CHALLENGE WINNER, 2007 best 1/4 mile - 11.24@120 mph
  #5
Old 05-25-2011, 05:30 AM
ecc_33's Avatar
ecc_33 ecc_33 is offline
Junior Member
Default
yeah hes right, make sure you have a torx set thats in good shape
__________________
02 extra cab long bed
Thanks: CRANK IT UP DIESEL PPE ATS SUPER DIESEL MCRAT RACING
CREATURES OF THE NIGHT BES RACING
Carrillo rods, Hamilton valve springs, ATI damper, 60% bigger nozzles, head studs, S475 turbo, 4inch lift kit, ATS dual fueler, ATS Tranny,Bunch of SD parts,lobonte water injection, AD 165gph,
best time 11.63 at 116 49,200 miles
  #6
Old 05-31-2011, 01:45 PM
-Shep-'s Avatar
RCLB kind of guy
Default
Quote:
Thanks for letting us know about these shortcuts.
__________________
'04.5 LLYAllison
  #7
Old 05-31-2011, 02:21 PM
ku 808 ku 808 is offline
Default
I just did mine yesterday and it was a pain lbz are alittle diffrent worst when you have twins
__________________
LMM single cab 4x4 aluminum flatbed dually twin turbo built trans work truck
  #8
Old 05-31-2011, 05:06 PM
-Shep-'s Avatar
RCLB kind of guy
Default
Quote:
I'd say so!
__________________
'04.5 LLYAllison
  #9
Old 05-31-2011, 06:25 PM
Default
And it has to come back out the new one is worst now she is surging in idle befor only small kind when coming to a stop. F... owell I guess its part of the game.
__________________
  #10
Old 11-29-2011, 10:29 AM
-Shep-'s Avatar
RCLB kind of guy
Default
My reply from a similar thread over on DP...
I had dedicated my Saturday morning to doing this, looked down into the abyss where the fpr resides, and saw the intake crossover tube in the way. I went over my plan of attack and just couldn't muster up the balls to jump into it. I put the mouthpiece back on and here I am today searching again for LLY specific fpr replacement tips and tricks.
"Book time" says this is a 4.2 hour job. I want to do this myself in a bad way. I printed off the GM LLY fpr replacement procedure, but it doesn't say anything about getting around that intake pipe.
__________________
'04.5 LLYAllison
  #11
Old 11-29-2011, 02:37 PM
ecc_33's Avatar
Junior Member
Default
the neck that comes off the y pipe is got a rubber O ring that you just pry out then push back in after your done. I did a lly last month.
__________________
  #12
Old 11-29-2011, 10:27 PM
quadracer37's Avatar
quadracer37 quadracer37 is offline
Default
...just be carefull putting the y bridge inlet back in, the o rings fit around the inlet a little lose and they can get snagged easy going into the y bridge, causing a tear or broken o ring which is no good. at least the LBZ is that way, Havent done a whole lot on the LLY
__________________
'17 GMC Denali CCLB- The Latest Test Mule!
'16 GMC RCLB Shop Truck with 625HP Emission Intact WCFab Twin Turbo's & Exergy 10mm CP4 Pump
'15 GMC Denali CCLB- WCFab Twin Turbos, CP3 Conv. FOR SALE
'02 Chevy CCSB- The Original Shop Truck! Dana 60 SAS, Triple CP3's Currently S476/118mm Compound Set. Puller/Street Machine! Built By Wehrli Custom Fab
'76 GMC Puller with WCFab Dmax conversion
'87 GMC K2500- all original Classic!
'87 Chevy K30- Dmax Swap in Process! LBZ/ZF6
  #13
Old 11-30-2011, 08:23 AM
Jscherbs's Avatar
Jscherbs Jscherbs is offline
PIN IT TO WIN IT!!!
Default
great thread. sub.
__________________
2014 DMAX DENALI
03LB7ECSBLS
S475, EFI, M/A Trans, OUO Traction bars, BT Dieselworks Lock-up box, FASS260, LML Manifold, 2/4 drop, stack, 34" Nittos, SOLD!!!.
  #14
Old 11-30-2011, 02:37 PM
ecc_33's Avatar
Junior Member
Default
Quote:
Any time I rebuild a pump,cylinder or stuff with orings I use some Permatex engine assembly lube. Its like a white grease and i just give the O rings a good coating. That should make it slide right back in the Y bridge and seal up nice!
__________________
  #15
Old 11-30-2011, 04:58 PM
dmax711's Avatar
dmax711 dmax711 is offline
Default
Took me and a buddy an hour and a half.. the bottom hex bolt took prolly 20 mins by itself to get out. Its gm's idea of a sick joke.
__________________
Sold--2005 lly , built motor, triple turbos, dual pumps, 100 overs.
2012 lml Denali , deleted, ppei tunes, fass 150
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
