  #1
Old 03-12-2010, 06:43 AM
nick1camper nick1camper is offline
Gearhead
Default does an LLY have a DPF?
Hey guys. Recently sold my LB7 and upgraded to an LLY. I was wondering, does it have a DPF or is what I am seeing in the exhaust just a cat? Also, If I remove the front pipe can it be replaced with one from an LB7?
  #2
Old 03-12-2010, 06:46 AM
Akdiesel's Avatar
Akdiesel Akdiesel is offline
IFS Hater
Default
No an LLY doesn't have a DPF. Yes the weird can thing on the front pipe is a catalytic converter. Can't answer the one about LB7 downpipe though. Hope that helps
__________________
USMC/OIF Veteran
2005-2014
  #3
Old 03-12-2010, 06:49 AM
KEVINL KEVINL is offline
Default
Quote:
yes it will bolt in
  #4
Old 03-12-2010, 06:55 AM
Gearhead
Default
Cool. Will it make a difference in the way it runs or the mpg if I remove it? I think I can get my hands on a stock LB7 pipe that doesn't have the cat. If it won't help I won't worry about it though.
  #5
Old 03-12-2010, 07:00 AM
Default
the cat is the biggest restriction so it will make it run better but I think you will get a code. might need a finger stick
Someone else will know for sure.
  #6
Old 03-12-2010, 07:02 AM
Gearhead
Default
IC. I have been thinking about an EGR block off plate and a finger stick as well. May as well get it done! Thanks for the info!
  #7
Old 03-12-2010, 08:16 AM
Redbowties88's Avatar
Redbowties88 Redbowties88 is offline
Sideways > Straight ;)
Default
mbrp also sells cat delete front pipes for a little over 100 bucks...
rarely will you get a code but it is possible....i would do the egr block and cat delete and if it throws a code then get the fingerstick....n my experience ive found that most dont unless its a cali or MA truck.
and yes it is worth ditching the cat... that makes more of a difference then the whole rest of the exhaust IMHO
__________________
Beech - 05 cc/sb
12.31@108.57 stock turbo/fuel 1.63 60'
BigDipper, Eaton, Duramaxtuner, Calvert, EFIlive, Falken
  #8
Old 03-12-2010, 08:53 AM
Noreaster's Avatar
Noreaster Noreaster is offline
Default
the factory muffler is worse than the cat
__________________
02 GMC 2500HD RC/LB "No Shuckin Luck" Totaled 12.26 @ 109
Ridge Runner Diesel Performance, Big Dipper tranny, Profab Performance, Super Diesel, Creatures of the Night, AirDog, BD
02 GMC 2500HD EC/SB WCFab twins
Bay State Diesels
  #9
Old 03-12-2010, 08:59 AM
Default
i run with a cat an no muffler first....sound changed only a little..egts barely moved either.
dumped the cat and it was a whole different ball game....just what happened in my case..
__________________
Beech - 05 cc/sb
  #10
Old 03-12-2010, 09:04 AM
TeaBagger2006's Avatar
TeaBagger2006 TeaBagger2006 is offline
Im a Garrett Nut Swinger
Default
for a moment i forgot these things have all tha garbage
__________________
Joe
Loosest Tailgater in USA
2006 GMC 3500 D/A LBZ SRW CC/LB SLT 4x4
8" Fabtech lift 37x13.5/20 tires....Mike L trans....some go fast goodies
13.20@106mph
'06 Jetta TDI
  #11
Old 03-13-2010, 04:55 AM
05' Ditry Duramax's Avatar
05' Ditry Duramax 05' Ditry Duramax is offline
Default
Quote:
Me too. I don't even remember what all that stuff did when I ripped it off. I took all that out day 2 after delivery.
If you take the CAT out I think you might get a 0404 and a 0401 code (I can't remeber). It will not set the CEL but they will be in there forever. Maybe if the truck is a CA truck it might set the CEL.
__________________
05 LLY C/C SB
Moving right along. Gonna do stuff this summer.
  #12
Old 03-13-2010, 06:35 AM
Default
Mine never got any codes at all even dormant ones. I ran straightpipe and an egr plate on stock ECM tuning
__________________
Beech - 05 cc/sb
  #13
Old 03-13-2010, 06:57 AM
Triple L's Avatar
Triple L Triple L is offline
Lots of learning
Default
Myn popped a code immediatly... Went to the drag strip and made a couple passes and it disappeared and never came back on... Seems like ripping on it made it recalibrate....
  #14
Old 03-13-2010, 07:53 AM
Cougar281's Avatar
Cougar281 Cougar281 is offline
Default
Exactly. If it's a Federal Emissions truck (it would have FE9 on the RPO tag), it may set codes but shouldn't set a CEL. If it's a CA/NE truck (RPO NE1), it'll probably set codes and a CEL.
__________________
'04.5 2500HD Silverado LT CC/LB, LBZ D/A Dark Grey
Metallic, 05+ HD Hood & Grille, 192k and counting
Mike L Trans built by ME.
EFILive, PPE Race Valve, KD Twin Lift Pumps & Billet Fuel Pickup, MBRP 4" "Cat-Back" T409 straight piped.
300.59' 3rd place first pull
Best 1/4 times:
Truck: 14.067 @ 96.29, weighing in at over 7200#
446.4RWHP/820.2RWTq
Car (95 Cougar 4.6L V8): 14.680 @ 94.00
"The FIRST weapon is the mind, all others are incidental."
"I'd rather be judged by twelve than carried by six."
  #15
Old 03-13-2010, 10:16 PM
Default
Quote:
That's what I thought. i couldn't remeber exactly though. I'm not going to go back and dig thru a crap ton of old threads.
__________________
05 LLY C/C SB
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
vB.Sponsors
