  #1
Old 04-23-2009, 09:27 AM
dbtravis's Avatar
dbtravis dbtravis is offline
is rattling my brain out
Default limp mode?
is that when your trans goes to downshift, loses power, stays in 4th gear, won't allow you to go in reverse? cuz that happened this morning (again) and after a quick shut off/on it went in reverse... how bad is that?
__________________
2005 CHEVY 3500 CC, LB, 6" RCD LIFT
4-15" subwoofers + 5KW amp = no hearing left...
  #2
Old 04-23-2009, 10:25 AM
Mike L.'s Avatar
Mike L. Mike L. is online now
Default
What was the code?
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #3
Old 04-23-2009, 11:11 AM
dbtravis's Avatar
Default
I don't remember the nunber but it was "incorrect 5th gear ratio"
__________________
  #4
Old 04-23-2009, 11:45 AM
Bako_Dmax's Avatar
Bako_Dmax Bako_Dmax is offline
GTO Slayer
Default
Was it p0735?
__________________
2006 Chevy LBZ
MBRP exhaust, Shimmed FPRV, Blocked EGR
Homemade Lift Pump W/ Bypass
Homemade Pitman & Idler Braces
Tierod Sleeves
EFI Live
Built trans w/ triple disc
Homemade Twins S475 w/ 38mm gate
  #5
Old 04-23-2009, 11:56 AM
Mike L.'s Avatar
Default
Quote:
Originally Posted by Acoombs View Post
Was it p0735?
Sounds like it to me. That is a limp. Need to upgrade the Alli.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #6
Old 04-23-2009, 12:12 PM
dbtravis's Avatar
Default
Quote:
yeah I need to price one out. like a stage 4 suncoast or ATS...
__________________
  #7
Old 04-24-2009, 03:56 PM
dbtravis's Avatar
Default
they said P700 Transmission Control Unit
__________________
  #8
Old 04-26-2009, 11:52 PM
Black & Silver's Avatar
Black & Silver Black & Silver is offline
FNG
Default
Mine is doing the same thing all of a sudden, doing about 70mph then jump on it it will down shift and then sticks in 4th or 5th gear. GMC replaced the shift module the first time, found nothing the second time and now it is back in the shop. Please help what is the solution?
  #9
Old 04-27-2009, 12:02 AM
LBZ's Avatar
LBZ LBZ is offline
Default
Quote:
Does your check engine light come on when it does this?
  #10
Old 04-27-2009, 12:17 AM
FNG
Default
yes the light comes on
  #11
Old 04-27-2009, 01:01 AM
LBZ's Avatar
LBZ LBZ is offline
Default
Time for a tranny!
  #12
Old 04-27-2009, 05:16 AM
Cougar281's Avatar
Cougar281 Cougar281 is offline
Default
Quote:
Who's "they"? The scanners they have at ricerzone usually can't pull the TCM codes, so the only one they's get is the P0700 that the TCM sent to the ECM. As everyone above said, sounds like you limped it; start saving .
__________________
'04.5 2500HD Silverado LT CC/LB, LBZ D/A Dark Grey
Metallic, 05+ HD Hood & Grille, 192k and counting
Mike L Trans built by ME.
EFILive, PPE Race Valve, KD Twin Lift Pumps & Billet Fuel Pickup, MBRP 4" "Cat-Back" T409 straight piped.
300.59' 3rd place first pull
Best 1/4 times:
Truck: 14.067 @ 96.29, weighing in at over 7200#
446.4RWHP/820.2RWTq
Car (95 Cougar 4.6L V8): 14.680 @ 94.00
"The FIRST weapon is the mind, all others are incidental."
"I'd rather be judged by twelve than carried by six."
  #13
Old 04-27-2009, 04:49 PM
FNG
Default
ok so what is the fix, a new trans ? and how or what do you do to stop it from happening again?? Thanks
  #14
Old 04-27-2009, 05:45 PM
Cougar281's Avatar
Default
Rebuild. Once it's limped once, it'll get easier each time. Eventually, it can get so bad it won't even hold 5th with a stock tune.
__________________
Best 1/4 times:
446.4RWHP/820.2RWTq
  #15
Old 04-27-2009, 06:02 PM
FNG
Default
Quote:
ok so the whole thing or is there certain parts that need to be beefed up so this doesn't happen again? Thanks for all your help
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
