Old 04-03-2018, 10:45 AM
fl0w3n fl0w3n is online now
FNG
Default Fuel tank difference between LB7 and LLY/LBZ
Are there physical differences between tanks, other than fuel pickup?
I found a transfer flow 45 Gal tank that's advertised for 04.5-06, and I'm wondering if it will bolt up to my 02. I know the pickups are different for LB7, but I'll be modifying that anyways for my liftpump.
2002 LB7/ZF6 CCSB Sierra 4x4
340k miles
Stock...for now
Plans:
KP D60 front, ORD leafs front/rear, Twin Stick NP205, 4.56 gearing locked rear, PSC steering/hydro assist , 37"s on H1 wheels, Titan or Aerotank replacement
SAC45% Injectors, SB SD clutch, Kennedy pump and filter heads, S&B intake, ProFab up/down pipe, manifolds, Mild Tune from Rob
Old 04-03-2018, 11:07 AM
Burn Down's Avatar
Pretty sure it physically bolts in the same.
Old 04-03-2018, 01:01 PM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
Bolts in the same but sending unit on LB7/LLY is different than LBZ/lmm
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 9.72 @ 150.
06 Cummins cc/sb EFI by Hardway.
Tailgate Member #1 I prefer the backdoor
Old 04-03-2018, 04:08 PM
FNG
I'm looking at part numbers between factory tanks and it looks like there's a split where one number is for 01-04 and another for 05-10
I'm debating whether the price is worth it to give it a shot anyways
340k miles
Stock...for now
Plans:
Old 04-03-2018, 04:16 PM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
Maybe give Transfer Flow a call and see what they say. They might even be able to set you up with the correct mounting hardware, if there is a difference.
Let us know what you find out too, I'm curious.
Old 04-03-2018, 05:15 PM
FNG
I called them they were very nice and they were more focused on telling me the way to tell 04.5 split from VIN and that fuel sending unit was different, but also mentioned dimensionally they are different.
They sounded like the guy knew his stuff, but he said the current tanks fit '04.5 to '10 LLY/LBZ/LMM
I don't want to believe that they changed under bed dimensions etc from 04 to 04.5 but then again I'm not an auto maker.
340k miles
Stock...for now
Plans:
Old 04-03-2018, 05:22 PM
TheBac's Avatar
TheBac TheBac is offline
Mounting-wise, the tanks will be the same. The frames, 01-07, with the same body config are all the same.
I think the 04.5-up sending unit has a larger.different locking ring.
Tom
"BBT" 2003 GMC CC/SB 4x4
12.14@111.15
"Flyin' Brick" 1999 Chevy 1500 RC/SB 2wd -- stalled out, no motivation
From mufflerguy on yb,
