Old 03-15-2018, 07:51 PM
calereeves calereeves is offline
Displaced Texan
Default Nitrous effect on EGT
Anybody logged EGTs with vs without nitrous on the same tuning? Curious whether it increases or decreases... Seems like the charge cooling should be fairly significant, but at the same time increasing the cylinder pressures would(?) increase EGTs. Which one wins out?
Old 03-15-2018, 09:15 PM
2004LB7's Avatar
2004LB7 2004LB7 is offline
The way I see it there would be a negligible change in pressure unless you are running really rich and the nitrous allows you to burn more.
The reason for the increase in cylinder pressure is due to nitrous allowing you to inject and burn more fuel
Of you where running clean with minimal smoke and injected nitrous I don't think there would be much if any pressure change unless you injected enough to cool the cylinder down
I could be way off too...
2008 Chevrolet 3500HD DRW LTZ
Old 03-16-2018, 03:39 AM
Yngdmax92's Avatar
Yngdmax92 Yngdmax92 is offline
Some guys on here got a little wild with nitrous. I feel like it cools egts when used properly
Sent from my Pixel 2 using Tapatalk
2003 2500 hd cc/sb (leftovers) MPS 63.5 ihi, built trans, airdog 150, 30 overs..... Sold
New and improved! 2007 classis lbz LS ec/sb
Egr delete, pcv re-route, PIPED, airdog 4g 165,
Danville performance tunes.
Old 03-16-2018, 06:39 AM
Dozerboy's Avatar
Dozerboy Dozerboy is online now
That’s the thing there are so many variables who knows. And if you had the air to run clean why would you run NOS other then spooling. Unless you where over fueling so hard it was putting out the fire I would think EGTs should drop.
06 GMC 2500 CCSB SLT LBZ 4X4
Old 03-16-2018, 07:50 AM
DMAXchris's Avatar
DMAXchris DMAXchris is offline
Here we go again
Because more power!
On a stock fuel truck n20 decreases EGT to a point. Once you start injecting more n20 than you need is when EGT goes through the roof. We were seeing 1800Ί on WOT runs with a .099 jet on a stock motor.
06 Chevy LBZOlympic White • Built Motor/Trans • Bullseye s375 • 45% Injectors • Stock CP3 • Built and Tuned by Blackout Performance 11.76@115.12
08 BMW 528xi
Alpine White • Brown Dakota Leather • Premium/Cold/Smoker Pkg • LED AEs • MTec D1S • 50% tint
2000 Buick Regal GS
Bright White • Lowered • Homemade CAI • 4500K HIDs • Supercharged • Beater
Old 03-16-2018, 07:53 AM
2004LB7's Avatar
Yeah, forgot to mention EGT. I would think it would be less if nothing else changed. Instead of ramming in several hundred degree air with turbos you are injecting cold nitrous. So at least the start temp is lower which should have an effect on exhaust
Old 03-16-2018, 08:02 AM
DMAXchris's Avatar
Here we go again
It really all depends on how much fuel is available. A .030 will act totally different on stock injectors compared to 100%s. You might see an increase in EGT with bigger sticks and n20
08 BMW 528xi
2000 Buick Regal GS
Old 03-16-2018, 12:09 PM
torqued2dmax's Avatar
Would you be able to use n2o for towing , like when you need just a little bit of cooling as you are about to crest the top of a grade loaded heavy , with a very small nozzle , just enough to hold EGTs ? Like water meth , but might be safer ? I have those three plugged ports in my y bridge that keep calling for something to be installed in them ! LOL !
05 CC/LB DRW LLY Allison
  #9
Old 03-16-2018, 01:02 PM
2004LB7's Avatar
Straight up water would be the safest for reducing EGTs if one was unwilling to reduce throttle
It is quite effective and cheap
  #10
Old 03-16-2018, 01:50 PM
Thanks for the reply , there seems to be no end to the gadgets we neeeed ! LOL !
  #11
Old 03-16-2018, 04:19 PM
Dozerboy's Avatar
Use distilled water if you do. Short term might not matter, but long term the minerals in regular water start to deposit in the oil and does who knows what.
  #12
Old 03-16-2018, 06:22 PM
I think I will take the advice from both of you because the more I think of it , you can buy distilled water in any store but you cant do the same with n2o ! Thanks ! Mpg Tow Max ?
  #13
Old 03-16-2018, 09:27 PM
Displaced Texan
I had Mark add in additional fuel on my big tune so that I can spray it. I've got an NXd kit in The garage, but I'm going to hook up an 8- channel egt logger before I install it though.
