So if i was to remove the three 17mm bolts that hold the turbo down will it move toward the firewall say 2 inches?
Reason being, i need to get the y bridge out.
I cant get to the bottom back bolts and the top back bolt wont come out cuz the compressor housing of the 4094vgt is in the way of extracting the bolt
So if i pull he three bolts that hold the turbo, what else would need to be loosened?
I figured the up pipes and downpipe should be it? Right?
Thanks for the help!
