Zf6 t-case brace
05_LLY
Out-A-Time
Aug 7, 2006
1,756
42
Norvelt, PA
THere is no tail housing extension on the zf, its pretty stout, no need for one, the internals of the trans will break first, and that pretty hard to do!!
Yellow Jacket
WannaBe Sled Puller
Feb 11, 2009
917
Waterloo, IA
I'm not sure I agree, I have a zf6 with the entire flange busted off and the transfer case flopping around right now.
His carrier bearing was out and causing a vibration slightly, and there was a spring that had fallen out of place in the factory dual mass flywheel causing the engine to seem to run a little rough also...
Truck is getting a southbend clutch and flywheel and now getting a rear zf6 transmission housing and a transmission mount and carrier bearing...
RobsDmax
832
Arthur, Ontario
http://dirtyhookerdiesel.com/i-17844252-dhd-100-185-gm-zf6-to-transfer-case-support-brace.html
Yellow Jacket
WannaBe Sled Puller
Feb 11, 2009
917
Waterloo, IA
Yes, I had already ordered one, I was just posting my .02 cents and my personal experience, so someone didn't think they were bulletproof...
They do break and there is a brace being produced for a reason...
