LBZ: Yea Tony's EGR Delete and SS line kit
Colt
Jul 23, 2010
523
Put these on my truck 6 months ago and no leaks of fluid from GM leaking lines and my oil is so clean after 6 months from EGR delete and the extra power is so cool as a side benefit. Great job and quality craftsmanship, fit and results from these All Season Products! Just saying get them if you're on the fence deciding about it you won't regret them on your LBZ. They really make guys with regular LBZ stuff go wow that's cool, the sound and fit is great...... nuf said.......
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
Agreed,installing our 5th Allseason kit now.Awesome fit and finish.:thumb:
Combine Pilot
They Call Me Mike
Feb 7, 2010
647
Saskatchewan
I am very impressed with the fit and finish of Tony's kits. My EGR delete fit perfect and looks great. I went with Tony's kit because i wanted to keep intake heater on my truck and i read lots of good things about his products. I would definitely recommend it to anyone looking for an EGR delete kit. :thumb:
coldLBZ
Apr 22, 2007
2,344
Alberta, Canada
Got any pics? Also, did you go with the Y-bridge as well or just the delete pipe and the stock Y-bridge? Thanks.
blk smoke lb7
Nov 8, 2010
5,694
57
belvidere,ill
Dont waste your time without the y bridge if your pushing over 38 40 psi you will blow the stock elbow right out Ask Arnesn or cocker3658 both victims of the y bridge elbow blowing out.Both of them have twins tho.
Combine Pilot
They Call Me Mike
Feb 7, 2010
647
Saskatchewan
Why yes, i do have some pics. Took em with my cell phone in the garage so they aren't the greatest but they work. :)
Should have cleaned the motor up and turned on some more lights but i can take a couple better pics if neccessary. I did not replace the y-bridge but i replaced the up pipe instead of capping the EGR feed.
Combine Pilot
They Call Me Mike
Feb 7, 2010
647
Saskatchewan
Install wasn't bad. Up pipe was the worst part. I took the front pipe off my exhaust and that made it easier to get the downpipe out. Wish I had a new downpipe sitting there when I did it but now that I had it out, it isn't bad to do. Downpipe clamp was in a bad spot so I had to take the glow plug controller off to get at it. I made sure I sprayed the bolts with WD40 for a couple days before I installed it and didn't have any trouble with bolts.
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
I really like my all season hydroboost lines and the all season y bridge changed my truck, literally, it has been one of my best/favorite mods, well maybe thats a little much cuz efi was pretty sweet, but the high flow y bridge seemed to bring all the other mods "together" so to speak, that one part, after a bigger turbo, intercooler, down pipe, exhaust, manifolds and up pipes, made a huge difference, huge, cleaner exhaust, faster throttle response, less lag, moar powar....win win
Thanks Tony!!!:hug:
:D
arneson
Aug 14, 2011
2,133
stoughton, wisconsin
:thumb:. Ill be ordering one here real soon. Sick of my stock junk. And mine has 2 braces currently tryin to hold in the stock crap. I cant wait for tonys high flo kit. Dam new house i built ate all my play money up for a bit. Startin to finally recover. Lol
fatboylmm
54
Hey cocoal could you post a pic of your kit installed all polished up ? That bridge looks good
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Got a pic from looking into the exits of that y bridge? That looks awesome, I figured they just run into a "wall", looks tough to build. Scott that 3rd pic looks like an sdp delete pipe, isn't it?
Sent from my PC36100 using Tapatalk 2
blk smoke lb7
Nov 8, 2010
5,694
57
belvidere,ill
LOL it sure is good eye.I loaded it on accident and couldnt figure out how to erase that 1 pic so i let er fly.:spit:
