LMM: WTB: Turbo oil drain tube
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
I need a turbo oil drain tube for my LMM. Pretty sure the LBZ is the same, either way I just need to cut it and weld a fitting for the riser on the 366.
Let me know if you have one laying around, trying to get this here and welded so I'm not doing these things during the install.
Thanks,
Russ
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
I know when we changed out an lbz to an II 366 the drain line had to have a small section cut out and a pie e of hose with 2 clamps on it.If you use an lb7 drain tube you shouldn't have to cut it at all.IIRC
jmaz268
Lead from the Front
May 20, 2010
2,895
40
Springfield IL
I have these 2 gems in the garage.... The extension is for LB7 though.
blk smoke lb7
Nov 8, 2010
5,694
57
belvidere,ill
Russ if you don't have the the short extension that John has in his pic that would be a.good piece for.you to get if John has it for sale.
