Would this be legal?
moneypitt
MFNG
Jan 1, 2014
182
WA
Would this be legal for sportsman in the Summit Racing ET bracket Series?
The BD-Power 1057727 Staging Limiter for your 08-14 GM 6.6L Duramax eliminates over or under boost launches. This easy-to-install module allows you to preset your best turbo boost or engine RPM launching parameter so you can focus your eyes on the lights – keep holding your accelerator pedal on the floor then release your brake pedal for consistent launches. Great for all racers - especially bracket racers. Includes factory and universal connections with dash mounted controls. Works with height adjustable pedal assemblies!
This is what it says in the rules:
12.0 Sportsman (12.00 and slower)
12.1 Computer: Prohibited unless stock OEM or OEM replacement. See General Regulations 9.1 in the NHRA Rulebook.
12.2 Data Recorders: Prohibited. See General Regulations 9.2 in the NHRA Rulebook.
12.3 Delay Boxes: Prohibited.
12.4 Transbrake: Prohibited.
12.5 Line Lock: Four-wheel line lock prohibited. Two-wheel line lock permitted on non-drive wheels only. Line lock switch must be NHRA-accepted.
12.6 Automated Shifter: Prohibited unless OEM equipped. Electronic or pneumatic shifter permitted; must be manually controlled by driver.
12.7 Throttle Control: Throttle must be manually operated by driver. Electronics, pneumatics, hydraulics or any other device may in no way affect the throttle operation. A dead-stop under the carburetor linkage or gas pedal us permitted. Throttle timers and counters are prohibited.
12.8 Ignition: Stutter boxes prohibited. Single stage “high side only” rev-limiters permitted. Rev-limiters or any other rpm limiting devices, legal unto themselves but altered or installed so as to function as a down-track rpm controller is prohibited. Crank trigger system prohibited unless OEM distributorless ignition. Ignition systems equipped with built-in two step rev-limiters must have the “low side” (start line) function disabled.
12.9 Switches and Buttons: Must be standard mechanical connection type. Infrared lasers, retinal scan, fingerprint, light source or any other non-mechanical type switch and/or button is prohibited;
12.10 Tow Vehicles: Prohibited.
PACougar
2,105
41
El Dorado Hills, Ca
It doesn't look like you could run your truck anyway, clearly no "tow vehicles" allowed:)
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
I would say it violates this rule and any good tech or competitor would probably agree and call you on it. It changes signal at the pedal hence electronically controlling throttle.
moneypitt
MFNG
Jan 1, 2014
182
WA
Thanks, that's kind of what I was thinking. So I guess they make these for different classes of drag racing.
