Iv noticed the last 2 months my pyro has been sweeping really fast, and boost usually runs 15-20psi max.... Changed the fuel filter a week ago (nicktane adapter) & bled it out....about 2 startups later it just cranked & cranked....bled it & no bubbles....then i hit the primer with bleed screw closed & it fired right up. It kept doing that so i took the whole filter head assembly off, cleaned all surfaces and put all new orings in (rebuiltit)and put another new filter on... Its still intermitantl 1 out of 5 startsy just cranking over till i get out & hit the primer till its stiff. I washed my air filter, its completly clean. No fuel is leaking around the filter head so i dont think its cracked.did a pressure test on intercooler & no leaks to 50 psi.....
Any ideas for the next step?
