LLY: wont build rail pressure
unionmax481
hot rodder
Aug 8, 2014
222
lebanon in
Just did a lb7 lly swap its the the same engine in my sig just lly now . The most i can build is 14-1600 when desired is at 6000 changed fpr still nothing. I checked the return on the injectors very little return on then but a lot of fuel is returning from the pump i don't now what else to do with it any input helps thanks
