Wondering who run without glowplugs?
ZeroGravity58
1,401
51
Maryland
i was just sitting here thinking about who runs without glowplugs. If you do run without glowplugs what type of weather is it? Im just thinking out loud here but i know a few on here run without them.
JOHNBOY
< Rocking the Big Single!
Aug 30, 2006
2,159
Saegertown, Pa
I tried running without the glowplugs and intake heater. I dont reccomend it. I like the the fact that it will start the first try and stay running when it gets below 50*.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
In warm climates, it's OK with stock compression. But if you lower the compression, I'd keep them in.
It's pretty easy to test, just unplug the power lead from the glowplug controller.
radvans
242
SoCal
I ran without mine for 8 months. Controller was bad and I didn't know it till Greg noticed it. Never had a problem starting it.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Whats to advantage? Besides not having to buy new ones when they go out :D
3 minor advantanges i could see would be
-No interferance with the fuel shot
- If the glow plug tip breaks off, you have to pull apart the motor
-weight reduction:joker: you could lose some of the wires and GPC
Josh2002cc
That Uncle
Apr 2, 2007
1,832
Can glow plug eliminators be had for less than $400?
Could one make a plug to insert instead of an entire glow plug on a built motor and if not why do they have to be the same length as the glow plug eliminators that are currently for sale?
550
pending C/R you can get and either bunny in front of your truck :rofl:
DD i dotn see the point...... all out race app sure....
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Not buying new ones when they go out.
Weight reduction.
Funny stuff there.
:rofl: :rofl: :rofl:
atleast 1lb or wieght savings:D
the holes would fill with carbon is my geuss
x2
SmokeShow
6,818
Lawrenceburg, KY
if the plug didn't go all the way to the cylinder then you'd be decreasing the cr even more by increasing the bore capacity wouldn't ya? Same as shaving a bowl or piston top.
Rhall
Old Skooler
Aug 12, 2006
2,241
41
Texas Y'all
The bad part is glow plug eliminators are more expensive than buying glow plugs unless you make your own. I just bought 8 brand new glow plugs for like $36 a piece, are there eliminators out there for less than 250? I really dont see an advantage, might as well leave them in and have easier starting.
