I'm in the process of cleaning up my wiring harness (removing all the plugs and wires that are not being used. Can someone tell me what this connector went to? It's along the back passenger side of the engine. Working on a 07 LMM, Thank you.
The only one I can see on my LMM is a bracket on the left side of the EGR, it has two electrical connections going to it? One looks similar to that connector.
That looks like it's it, where does it go to?
You were spot on.
The deletes where done a while ago, changing up cp3's and injectors. I'm waiting on stuff to come back from the powder coater, I'm trying to remove all the wiring back to the bale connectors instead of just gutting the ends off. Should clean up under the hood a lot. I got some of the wire loom that looks like braided hose.
