Wire harnesses
Vreeble
May 20, 2017
13
Hello, new here. Thanks for looking. So here's the story. I have a 2005 duramax that caught fire in the cab and subsequently burned everything in there. Spread to engine compartment and of course all of the wiring is screwed, along with pretty much all the plastic and rubber. I need to know what years wiring harnesses I can transplant. I am going to put a 68 body on the frame so anything I can delete would be good to know as well.
CarolinaHD
969
NC
For the interior harness behind the dash a 2003-2007 will work but some wires will have to be arranged if it's an 06-07.
Both engine harnesses will need to be from a 2004.5 or 2005.
I have an interior harness that runs behind the dash and through the firewall to the fuse box if you need it.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
I have a 05 truck side engine harness and fuse box. Plugs into the fuse box and runs to the motor, tranny, t-case, ECM and tcm. $300 for harness and fuse box.
Vreeble
May 20, 2017
13
Vreeble
May 20, 2017
13
Thought you all might appreciate the work of stupid employee
Vreeble
May 20, 2017
13
So I guess the biggest cost will be replacing the computer? and I need the vin to reprogram? What problems am I facing?
1,866
ECM is the least of your worries. Injectors, turbo, all the plumbing, hell...the CP3 might even be toast. You're going to be replacing basically the entire top half of the engine.
Good luck.
Vreeble
May 20, 2017
13
I don't think it got that hot in there. Here is, in order right side injector, left side injector, turbo vane controller.
