Wiper issues
907a4
Nov 17, 2010
15
Alaska
Hopefully someone can help me as it just started snowing here in Alaska last night. I've got a 05 LLY that was completely base model, I recently swapped in the entire dash harness and both fuse boxes etc from an LT truck so I could have power door locks/windows etc. everything works great, other than now my wipers won't work at all. They worked fine prior to the swap, and I have checked all wiper fuses/relays and connections to make sure I didn't forget to plug them in. Does the clock spring have anything to do with the wiper function? I thought maybe the switch was bad in the turn signal lever but all the other functions work, such as cruise, signals and brights.
I'm lost and need help!
