Winter Timing
tractor
293
9
59
Spring Creek,NV
Can anyone tell me if there is a table to take timing out when it s cold.
Dont wont to change all my timing tables but need less timing when itis very cold in mornings.
Thanks Darryl
rcr1978
790
Spring Creek, NV
For cold starts use B0952 thru B0957, B0955 would be the quickest and easiest route for you that should be the table it uses for our altitude. These tables are only good for 133 degrees and cooler. If it rattles after completely warmed up look at the tables sweetdiesel mentioned B0982, B0983
