Will this setup work?
Krazykid
<-Daily Thought Process
Nov 22, 2008
247
Upstate, SC
Well I have received my PPE Lift pump from McRat Racing the other day and I'm working on the installation pieces. I have attached a very crude drawing of what i have in mind. If I splice into the 1/2" Fuel line on the frame rail with a couple of T's, I was planning on mounting the PPE Lift pump inverted on the brace between frame rails just in front of the Fuel Cooler. Now the T's are for a pump bypass, as I only plan on running the pump at the track or while using a race tune. Please let me know if you see any problems with this idea?
JMK777
16's, but i keep em clean
Mar 20, 2008
1,433
5
Moss Beach
this might help you if you dont need to run a return line Im not familiar with the kennedy pump.
Krazykid
Nov 22, 2008
247
Upstate, SC
What is this check Valve? (i'm assuming the same thing as a diode?) And I'm guessing the mounting location and position are fine? Also the way I was planning on plumbing the T's, any issues?
RPM, your picture is what I started with NICE job, just to rich for my blood.
tinman22
715
Stillwater NJ
yor gonna need a check valve ( Brass piece on top in RPMs pic) or a flapper of some kind so when the pump is on it wont short cycle the fuel around itself and sends it to the motor
721
also if the pump fails on you the check vlv will open and allow fuel to by-pase the failed pump ;)
duramax3388
447
Zanesville Ohio
i had a really hard time finding one and i had to go to a specialty plumbing store to get it no one else in town had anything close to it. lowes had one that was an inch and a quarter but that thing was about 3in. around dont think thats going to work.
Krazykid
Nov 22, 2008
247
Upstate, SC
Thanks again for all that replyed. Quick question how to I releave the pressure fromt he 1/2" stainless line to spliuce in the new pump and bypass?
Krazykid
Nov 22, 2008
247
Upstate, SC
I like the idea of using the airgun to shot the fuel back into the tank. How much fuel can i expect to leak out when cutting in? 1 gallon, 5 gallons whats a lot of fuel? Going to cut the line tomorrow, just finished all the relay wiring through a switch in the Socal gauge mount, everything is working out so far. Hope to have this finished before Thrusday.........Race day! Thanks for everyones help and advice.
maxaholic
1,876
40
Central, Texas
If you blow it back with a airgun be sure and take the fuel cap off. When I did mine I actually pressurized my tank and fuel kept coming out of the line.
