will this set up get me into the 11's
cafryer
May 5, 2011
1,074
Utah
Hey guys i just got done with this setup and was wondering if it will get me into the 11's it has a socal built and balanced motor, 21lpm injectors, dragon flow cp3, and a s364/s474 turbos, im also running 285s and a grizzley locker and caltracs and the torsions lowerd all the way and 2" blocks in the rear
paint94979
Beer Nazi
Sep 18, 2006
11,715
what perfect over do those injectors translate too?
1,866
Good Lord I hope so.
battlegraduate09
Gearhead
Mar 18, 2010
610
with 2" blocks in the rear, id say leveled with aftermarket keys, and the stock ones turned all the way down. and yea im pretty sure you could at least hit an 11.8 with that setup. being very general of course though
cafryer
May 5, 2011
1,074
Utah
The injectors are 20% and it has a 6" rcd lift but it has been lowered all the way down it sits about 3" higher than stock but all my angles are level
cafryer
May 5, 2011
1,074
Utah
tires are 285 65 18 nitto dune grapplers and why does the lift hurt if the angles are all level ? It launches strait and does not get squirly.
custom8726
2,784
Upstate N.Y
That should only be around a 31" tire, so height wise I dont see that hurting your 1/4 time much. The fact they are fairly aggressive probably wont help but I have never ran the dune grapplers so I am only speculating on how they might hook on the asphalt. Aerodynamically the lift is not helping "obviously" but I dont see any reason you could not put that truck in the 11's with the right fuel/air/tuning.. If you actually weighed what is taking off the truck during the lift install VS what is being put back on I dont think you would see that much weight gain from the lift alone (excluding wheels/tires) I would venture to guess a 1/10th to maybe 2/10th increase in E.T. overall set at 3" with a 31" tire.....
custom8726
2,784
Upstate N.Y
On Edit I just looked up the 285 65 18 grapplers and they are listed at 32.6:eek: so unless there shot you might want to look into something a little shorter..;)
S Phinney
4,008
Quncy, Fl
If you can get it to hook well and have the right tuning you should be able to get there. I could run low 12's on 34" Nittos and couldn't hook up very good at all. I will soon be able to tell you what difference a lift will make. I took my off recently and will get some times soon.
