Will it spool
KEVINL
1,431
Phoenix, AZ
I have a 1057 converter with a 6" lift 35's and stock gearing I am getting a GT4094R turbo. This just occurred to me. Will I have lag problems with this setup?
03 D-max
Honorary "Tosser"
Apr 29, 2008
3,539
Lowville NY
what paint said the 94 shouldnt show you any problem at all and even if its a little slow to spool tuning should fix it... gt42 you might have problems
610
tho other will tell you differently;) i would get a .95 ar hoursing vs the 1.06 the comes standard option on them..
cruising at
55mph is ~1400rpms
65mph is ~1600rpms... boost guage is 0-2psi on flat ground
IMO the stock trubo is pretty laggy in those areas... i am sure the bigger turbo would amplifiy that..
when i towed my 75 form cali to OH anything under 70mph the truck had a hard time and lugged pretty bad when you hit any med size grade/hill.
personaly i re-adjust shift point in T/H via efi live to were 4-5 is ~65mph ~2300rpm helped fix that problem..
i know drew/paul dieselon ran a 4088 wiht 6" and 35" ran an .85 or .95? to keep egt in check while towing
15,681
I helped develop this converter on Casper in '05. Pat can tell you what turbo he was running but I think you are going to be fine. you may even like the converter better.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
simon doesnt know how to squat.... to be able to shit... :eek:
:rofl:
I had a HTT with a 1057 on a 7" lift with 35s......I think i can give a fair opinion:p It spooled very well for me and im pretty high in elevation.
What are you basing your info from, Adam:D
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
We ran the 1057 until we went to the GT42 May of 2007 and you put a ML Precision. Then later I believe you put in a 1055 ? same # that is currently in Casper.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
cruising at
55mph is ~1400rpms
The converter is only an issue in first gear launching as far as spooling goes. I towed a steel car trailer with car up some steep mountains with a GT40 with the 1.06 hsg with zero problems. If anything, the 1.06 GT40 spools harder than the stock turbo.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Please... :rolleyes:
I've spooled a GT42 with a 1057, it's just a matter of tuning. The converter is only an issue in first gear launching as far as spooling goes. I towed a steel car trailer with car up some steep mountains with a GT40 with the 1.06 hsg with zero problems. If anything, the 1.06 GT40 spools harder than the stock turbo.
The HTT I purchased from you Pat would spool very very fast:) It was alot to do with tuning,But it was faster than the stock VVT
610
i tend to agree... with one excception...
casper had "shorter legs" by ~10% then my truck, kevinL and simons when you are runnign the GT. iirc you were still runnign 3.73 vs 3.54 adn a ~30" tire vs 3.73 and 35" or taller
racing and DD... probly will not notice it..towing he will.
