Will H2 wheels fit?
D-MAX Mafia
Hood down, smoke up!
Nov 4, 2009
1,112
13
Phoenix
4.5-5" They should fit then. Found a set on craigslist with 285s for a screamin deal. Gonna swap them out when I go to the track. Hopefully I'll gain a couple .10s in the quarter.
jraymer
<--Tree Hugger
Oct 31, 2008
1,421
Las Vegas, NV
I know they won't fit on my RCD knuckle lift, I looked into a set 5.5 is correct. I emailed rcd and they gave me all the minimum back spacing for different diameter wheels. Maybe you could do the same with zone.
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
They are about 5.5. You can run them with a 0.40" spacer (stock wheelstuds will work). You can take a pair of front brake rotors and cut them down to work or you can buy them from Tony Burkhard at Allseason. If you are talking about machining the center section of the wheel where the lugs mount to it that would actually wind up giving it more backspace. I would call zone as suggested and see what the specs are. For instance a stock LMM 17" wheel WILL fit on trucks with the Tuff Country lift without spacers but an H2 wheel will not. So they are not the same backspacing.
