Wierd No start cond.
duramaxnate
Professional Amateur
Feb 18, 2014
513
32
Norco, CA
www.mcfooracing.com
I have an lly that cannot start by itself. Only with a shot of ether, actually it was brake kleen. (Bad thing I know.) Once it starts I can unplug the rail sensor and the FPR and no change. Swapped rail sensors, FICMs, ECMs and still same result. Truck has a new CP3 in it. I'm totally lost here.
Codes are
P1094
P0193
Can't really find anything on these and My shop cannot access TDS for some stupid reason.
5,818
im assuming you are saying the rail pressure is pegging out too based on you unplugging those sensors with "no change"
duramaxnate
Feb 18, 2014
513
32
Norco, CA
www.mcfooracing.com
Yessir, brand new from ppe. It has a ppe plug in it. Even blocked the return for good measure and same thing. The owner is bottle testing it today since it was getting late. The next thing I was going to have him do is swap engine harnesses for one I have in the shop to see if that fixed it.
Sent from my XT1650 using Tapatalk
5,818
no, i mean to return test each individual injector to see how much fuel each one is returning. just because the CP3 is new does not mean it will have the volume to keep up with high returning injectors while you crank it. once you start it, it may be moving fast enough to finally keep up and run but thats it.
Bottle testing the FPRV isnt a bad idea but if it passes, the next test should be a return rate test of each injector.
13,713
775
What does the rail pressure read with the key on and engine off?
duramaxnate
Feb 18, 2014
513
32
Norco, CA
www.mcfooracing.com
I had him do that today also. I gave him a tool I made out of a return nipple attached to a bottle that connects to each injector. First time we used it.. Lol.
5,818
It varies, sometimes it wants 3k and other times it wants 4k. I already told him he might need injectors. I had a feeling after trying everything that injectors are flowing too much return back but wanted multiple opinions.
im with ya. sounds like most of the "easy checks" are done. curious where josh was going with it though. he may have seen/know something.
13,713
775
I was thinking if it is showing 5800 psi at all times, even with the key on and engine not running, there was a sensor or wiring issue, but if it reads close to zero with the engine off, I don't think that is the case.
5,818
aaahh ok :D
duramaxnate
Feb 18, 2014
513
32
Norco, CA
www.mcfooracing.com
Truck is here now. Turns out the PPE plug was defective? :spit: Gonna load tunes back in the truck and see how it does. When it rolled up it had a slight fuel knock so now Im going to see what that is all about.
