Wierd Heated Seat Problem
gl4787
<-- just sits
Jan 27, 2009
274
WI
Does anyone have a clue why my passenger's heated seat will stay on forever as long as the driver's isn't on. Once the driver's seat is turned on and is on for about 15 seconds or so they both shut off. If the driver's seat is turned on by itself it will only stay on for about 30 seconds or so then shut off. originally i thought it might be a bad element in the driver's seat but now i'm confused. Any held would be appreciated. Thanks in advance. -Garrett
Burn Down
Sep 14, 2008
7,092
Boise Idaho
Mine does the exact same. Duratothemax said that a bad element would shut both sides off. My friend at the dealership said they have been having quite a few coming in with the harness rubbed through down by the rear of the seat. I haven't had a chance to look at mine yet.
gl4787
<-- just sits
Jan 27, 2009
274
WI
Great, that sounds sweet. Thanks man. Lemme know what you hear about this. If they put out a TSB for it or anything.
maine04max
Dec 11, 2008
1,009
on my truck neither seat works and drivers side power seat stuff doesn't work , even tho pass side power works fine . i have checked fuses and haven't found anything . the 1/2 seat memory doesn't work and no lights on heating part for either side .
anyone have suggestions where to start looking?
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
That sounds like a harness. Id replace the fuse for grins (located where yo plug a trailer brake in). Like Albert said check the harness located under the seat.
Sledhead
Mountain Pass Machine
Nov 29, 2008
884
BC
I had the exact symptoms. It was a burnt heat pad just had to 'unwrap' the seat and visually inspect to see. Mine was the seat back pad, check out the black part.
It's kind of like trying to get the top or bottoms off her in high school but determination gets it done :thumb::rofl::spit:
