Wicked Diesel CP3 help
04BWein
Feb 9, 2012
Hey guys, I recently purchased a wicked diesel 10mm CP3 from another member on this site. After actually installing the pump I have found a few odd things. The port where the high pressure fitting goes had a plug in it and there was a fitting on the back that was open. I switched the plug from the top to the back. Now high pressure fitting I took off of my stock LB7 CP3 is to small and is not going to work. My question is, will it hurt anything to have plugged the rear port, and where do I get the correct size fitting. I'm guessing i want a drilled fitting as well not just a stock one. Thanks, Brent
moparkxracer
2,309
33
Out and about
I'm guessing the pump was used as a dual fueled setup. That's how mine is setup, high pressure coming out the back of the pump. The fittings are different from my understanding.
dirtydmax
<---up shit creek
Sep 1, 2013
1,091
46
muskoka,Ont Canada
Post a pict of the hp fitting at back of pump if poss,Have never seen it done this way either so just curious.
