LLY: Why Cant I Get LB7 Idle? (EFI-Live)
TRUBBS
461
I dunno why my truck hates efilive so bad but i cant get it to rumble idle. i set all turbo vane Positions (A,B,C & Egr ON-OFF) between 0-1000rpm and 0-10mm3 to 5%, 10% 15% and 25% and seams that i just can not get rid of the hiss at idle, i used to like it but now i want to change it up and get it to ruble like an lb7 but not having any luck?
anyone got some tips as to what i might be doing wrong? maybe theres another table somewhere that'll cancel it out or something?
quinton
1,883
Granbury Tx.
Bet he didn't. Need to remember everything has a limiter somewhere. You have minimum and maximum vane tables. Need to adjust those first in areas you want to play with, then go back to your base tables and adjust as desired.
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
Not everything! :D
TRUBBS
461
Did you adjust the minimum vane position table to allow it to go that low %???
In all the maximum tables set them to 10% from 0 to 800 rpm and from 0 to 20 mm3. Then go to the minimum table and do the same
you guys are right, i did not mess with min table but i will now
table b2225?
can i set the area im going to be working in to 0 (Zero)? and jsut leave the rest at what it is? which is 6.00
Llys are gay :D that is all
mine just hates all things efilive.
i still cant get the damn thing to let it run a dsp5
