Who has`changed a rear inner seal?`Help!
DetailsUnlimited
1,264
Benton, Ar
Leaking rear seal p-side and bought a napa seal and it dosen't fit??? The ring,sleeve that fits the factory seal doesn't fit the napa one... so go to another parts store and buy another.....same thing? do I remove the factory sleeve or what??? anyone changed one before?
Thx
DetailsUnlimited
1,264
Benton, Ar
Did you pull the other seal out? The new one will be a tight fit. I can post the Gm specs in a few for you.
digging around(i did remove the factory seal and sleeve) I think your are supposed to remove the sleeve and install the new seal. I did this and I can barely move the rotor now. Is this what you are taking about?
