Whitish blue smoke.
Duramax_JP
1,088
I was sitting idleing at a stoplight today and noticed a whitish blue colored haze coming out of my exhaust. Is somethin wrong with my truck? I have heard of this happened before but im still not sure what it means. Any ideas on whats goin on? Also i may have out this in the wrong place. If i did mods please move it to the correct spot. Thanks
James
Duramax_JP
1,088
Well im not sure how blue it was now that i think of it. It was primarily white and a light haze
slowlmm
Mar 2, 2008
2,582
46
so cal
how cold out side was it when its starts getting in the low 30s and below they will smoke white simular to a gasser. thtats normal if it wasent cold out or aboove tht white is usally water from a head gasket or something.
03 D-max
Honorary "Tosser"
Apr 29, 2008
3,539
Lowville NY
any smoke or haze is usualy not a good thing unless it was burning water in the exhaust or something like that but if it did it after you had been driving it then it prolly isnt good:(
sillyboyrs4
Aug 19, 2008
86
De and FL
mine looked and sounded normal to me today, just a little puff and cleared right up!!!
we might be doing a compression test on mine in the next few weeks, might as well do yours too if your worried. Are you anywhere near Florida:joker:
Duramax_JP
1,088
Hah nope, Texas. I hope my truck is fine, it only has 43,000 miles on it and im only runnin a 90 horse tune.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
mine does this along with a slightly ruff idle when its below thirty degree's and i havnt plugged it in but i have a injector sticking i think . dont know on your lbz if its running smoothly just smoking , maybe post a video or picture of the smoke color .
Duramax_JP
1,088
Now that you mention it its been kinda shakin the truck at idle and is alot more rumbly rather than smooth at idle. I guess i can make a video of it tomorow. Its not very noticeable but its enough to make me worried.
TrentNell
Jul 7, 2008
7,543
slc tuah
mine only does it for 20 secounds or so on cold start up and then runs perfect post the vid and im sure we can help .
Duramax_JP
1,088
Ill post up a vid sometime tomorow evening when im free. I dont think it will do much good trying to make one tonight since its already dark.
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
Mine has done this before when it is cold out. After truck warms up it goes away for the most part. It did it when it was stock after I put the exhaust on it atleast that's when I noticed it. Check your balancing rates. Maybe it's just the fuel if it's winter fuel. Smell it.
radvans
242
SoCal
Mine started going blue before 3 injectors were bad. I thought blue normally meant fuel in oil? It was in my case.
