LB7: White smoke in engine bay! Need help!
Deerwashed
Dec 10, 2010
114
i put the title in capital letters because it makes it more important lol.
So my friend flips cars, he usually does japanese and american gas vehicles with a few ford diesels mixed in the bunch.
he recently bought an lb7 duramax with 250k miles from a guy who had a mechanic rebuild the motor, not long after the truck had tons of white smoke coming from the engine bay and didnt want to **** with it, so he sold it to my buddy for a very reasonable price all things considered.
he called me cause i know more about these motors than him but i had never seen this much white smoke at idle before. so much smoke its hard to trace.
need some help diagnosing. Here is what i noticed/know.
-smoke smells like diesel.
-smoke in engine bay increases when rpms are increased.
-number 8 cylinder is misfiring says scanner, but motor doesnt sound terrible(dont have fancy scanner for balance rates)
-original owner says compresion tested well
-intake leak also appeared as a code
-smoke appears to be coming from driver side, and when i saw the code for misfire i wanna say it could possibly be coming from toward driver side toward firewall(around number 8)
-upper rad was soft, no head gasket leak
-engine builder used some shitty gasket maker on upper valve cover
possibilities i believe:
is it possible the sleeve these lb7's have around the #8 injector could no be seated properly and leaking the smoke after it is burned in the injector? as instead of going out of exhaust port it is being pushed out and through sleeve? the smoke increases with rpms, so as the engine works more, it is pushing more smoke out around sleeve, and them out a little gap in the shitty gasket maker.
please let me know. i know it has to do with the shitty engine build im assuming it received.
i told him to find a good scanner and get balance rates first, but the misfire is making him want to pull the upper and lower valve cover off and get to the #8 injector first.
its a lot of smoke so i am just trying to think of possibilities.
thanks,
Hank
Deerwashed
Dec 10, 2010
114
Also, this happens at initial startup. i was thinking injector was leaking in head and kind of burning in the head, but it does it even with a cold engine so i didnt think the head would be warm enough to make diesel even smoke.
Deerwashed
Dec 10, 2010
114
The exhaust also smoking a lot? Maybe the up pipe bellow is cracked/broken and leaking exhaust into engine bay
i thought about a cracked driver side manifold, but no serious hissing. it would make sense too because the truck has no balls as if the turbo isnt spooling but i dont see much black smoke like the engine isnt running efficiently
Mwaterman1
Oct 30, 2014
54
pittsfield maine
Right but that coupled with a down injector might cause your issue, balance rates/return rates definitely need to be checked
Deerwashed
Dec 10, 2010
114
when my lly had a leak on my blocker plate it didnt produce any white smoke in the engine bay, but sounded like absolute ass through the leak.
this doesnt sound like absolute ass, runs fairly smooth, but it would make sense now that the white smoke would be a sign of bad injectors, but instead of coming out of the exhaust its coming out of wherever the leak/crack is in the manifold, which signals both a crack in wherever, as well bad injectors.
like i said its a fair bit of white smoke.
Deerwashed
Dec 10, 2010
114
i understand its exhaust fumes, because the truck has no balls as if the turbo isnt spooling so i know its exhaust related, just doesnt sound/have the screach of a crack/leak
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
If it has a major fuel leak that is running out onto an exhaust component that could cause white smoke and fuel smell from the engine bay.
Dkatubi06
114
Also, what about it burning oil and having a blown exhaust manifold gasket? Or a blown 8 injector and exhaust manifold gasket?
