which pedestal
crash85
Nov 3, 2009
47
i just bought an s475 1.32 ar 75/96mm used and i was looking for a pedestal and iam not sure which onei need and is there some where i could run the serial # to check it nd make sure of it? where is the best place to get a pedestal
paint94979
Beer Nazi
Sep 18, 2006
11,715
You should not be using a 1.32 turbine housing as a single... no way in hell. Look to a .90 or 1.0 T4. I really like my PPE pedestal with 2inch spacer
02bigstrokin
Sep 9, 2008
882
not only that but a 96mm turbine wheel is going to be a laggy bastard as a single. you need to just use that as a twin for your stock turbo.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Yeah, you need a lot of engine displacement to hang with a 1.32. That is normally reserved for very big engines running low boost, or folks running custom twins.
Your charger is perhaps a T6 if it has that big of housing.
There are no T6 off-the-shelf pedestals that I know of.
Measure the bolt pattern with a ruler and tell us what the center-to-center spread is in both directions.
crash85
Nov 3, 2009
47
ok ill get them tomorrow its at the shop what all do i need to set it up for twins
SmokeShow
6,818
Lawrenceburg, KY
I think Rick makes a pedestal with a T6 mount... That's not likely to make a good driving turbo though. They are used a good bit as a basis for a 2.6 pulling turbo though. :D
crash85
Nov 3, 2009
47
well iam working on a built motor and going pull in the 2.8 class but i would like to put it on the shop truck for twins
SmokeShow
6,818
Lawrenceburg, KY
do just fine as a twin to a stocker it seems. Or make a decent start to a good 2. charger. Sounds like you've got a use for it one way or another. :thumb:
