which clutch plates to go with
Teamvi
Oct 26, 2011
333
I see that suncoast offers two different brand clutches for the rebuild kits, can someone tell me what th e difference is and which one is better for what? Thanks
Awenta
4,090
CT
You tell us what you want to do and what your plans are. Then you'll get the best recommendations.
S Phinney
4,008
Quncy, Fl
I have rabestos in mine now. I have ran Alto before as well. Most builders seem to used a combination of both and a mix of steels as well. In general if you use only one brand there seems to be less problems with Altos. I'm sure that is also dependent on the application. Extreme hp doesn't mix well with either. It is not a do it one time and forget type of thing.
onebaddmaxxx
1,212
Cecil County Md
I just pulled a set of carbonites out of a transmission and they were pretty rough. I like the Raybestos clutches. The kits iv got from Evan have stacked out perfect.
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
My kit stacked out perfect as well. I ordered another raybestos kit from Evan this afternoon for an lbz I'm building next week.
rgullett83
1,607
Illinois
I havent ran the carbonite altos yet, but I really do like the raybestos clutches, other than issues with clearances with on c3/c4s. 6 out of the last 8 I had to machine the factory backing plates to get the proper clearance. The steels are consistent, but the frictions are very inconsistent from what i have seen.
onebaddmaxxx
1,212
Cecil County Md
Groove differences in cases possibly?
rgullett83
1,607
Illinois
Could be, but measuring the thickness of the frictions, showed quite a difference between them. Maybe I am over thinking that and it just is case differences
