Which Bilstein Shock for 4" Lift
2007LBZ
Piston Melter
Feb 18, 2017
17
TN
I am piecing together a lift for my truck and hit a small roadblock when looking for Bilstein 5100 part numbers. Bilstein's application guide recommends one shock for 0-2.5" of front lift, and another for 4-6" of front lift. I plan to do a 4" lift with the torsion key bolts removed, so the lift height should be somewhere between those two ranges. What shocks are you guys with 4" lifts turned down running?
2007LBZ
Piston Melter
Feb 18, 2017
17
TN
Be5-e710-ho & be5-b514-ho
Do you know what be5-b514-ho translates to with the new part numbers?
And if it makes any difference I'll be running Mini Deavers (about a 1 3/4" lift) and airlift 5000 bags in the rear, so less lift than most people running a 4"
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
I'll have to look on my site tomorrow and figure it out, I have the old numbers imprinted into my head :roflmao:. The 4" in the rear will be fine, you're only 1/4" shorter than a 4" package.
