LLY: Wheres this connector plug in?
jdlover1
437 Cubic Inches
Oct 4, 2006
538
chapanoke,nc
I was wondering if any of yall know where the oil sensor harness plugs in. I have both sensors plugged in and the ground bolted to the block but I cannot figure out where the other plug goes. I have a feeling it runs up behind the accesory brackets but then where does it connect to?
13,713
775
It runs behind the water pump, between the coolant pipe (the one that runs from the pump to the oil cooler) and the block, behind the thermostat housing crossover and behind the accessory mounting bracket. There should be a short pigtail sticking out of the main engine harness close to the large bale connectors right around the fuel rail.
It is a unique plug that will only plug into one spot.
