where to take my lb7 for diag in colo?
rings343
Jun 18, 2010
21
I know I need at least one injector who has the ability to tell me exactly which ones are bad I have axcess to autoenginuity and it is saying that 4 is at -7 does the tech 2 give any more info I really cant afford to wholesale change the injectors so I want to just get the ones that are crappy the truck smokes under load and there are no boost leaks
rings343
Jun 18, 2010
21
ats isint far but dont they usually just recomend all 8 actually I bought it from brian that used to work there oddly enough
Smokin LB7
Jul 25, 2008
191
They can figure out which one it is and will replace just the one if thats what you want.
Dealers always replace all 8 under warranty. But when you pay the bill, its your call.
So you got that little white truck running huh? How is it?
rings343
Jun 18, 2010
21
yep got it running it needed a head and a piston and a wastegate as well as a filter housing but it is running good except for the smoking I was planning on doing the injector myself but the only scanner I have access to has limited info in the injectors and I cant cut each individually so I need someone with more resources
