when pulling a lb7 where would one go about hooking the cherry picker to? i know its heavy and i dont want to screw up and hook the chain somewhere it shouldnt be hooked. thanks
:yup: when we pulled the motor on johnboy's truck we used the bolt in the back of the head on the right side of the motor and a accessory bracket on the front of the left head.
When I pulled mine out with the tranny I used the bracket on the passenger side rear head, and then removed the compressor and used the top bolt hole where the second alternator would bolt up. Worked fine and was balanced very well with the trans off and wasn't horrible with the trans on.
