Forgot all about transfer case express but got all the parts in and rebuilt it this evening. Had to tear it apart again because I forgot to install the new main shaft bearing in the new input shaft.
One question;
When I went to install the final snap ring on the output bearing I had to pull the shaft backwards roughly 1/8" to get the grooves to line up in the tail housing. Is this normal and does the front bearing in the input shaft need to be moved back as well?
