Where to get waste gate regulator
5,817
So found out today my stock turbo waste gate regulator has take a dump. On rhe tow tune Either total boost is 55psi and the big turbo is pushing 18psi or total boost is 40psi and the big turbo pushes 30psi.
After about 20 WOT runs adjusting the damn thing a nut hair at a time, I gave up.
Where do you guys get these regulators since I can't call up Trent no mo
5,817
You need to find an old set of Juice Grips. Best wastegate setup ever for the LB7.
Travis!! have not seen you post in forever! lol ooohhh juice grips.... it probably wouldnt work too bad on a twin setup :D
The new ones made in chiwanasia are not up to the task....
seems so
So mcmaster-carr has a ton of choices and of course non look like mine to make it that simple. what one are you guys running?
