Where does this go?
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
Not sure but i just put a bolt in the feed line and a plug into the steel coolant line. Its been like that for 3 years leak free
Mike_S
OOPS!
Nov 18, 2009
803
40
Idaho
The turbo coolant line that is not the one on the upper radiator pipe comes from the bottom of the thermostat housing IIRC, on the bottom of the coolant crossover casting. There is a nipple welded to yet another coolant bypass pipe. But my memmory could be a little rusty...
I would just cap the line at the end of the hardline near the turbo, and get a plug to delete the thermostatic valve in the upper pipe and call it gravy. :thumb:
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
So best thing to do it put a bolt in the rubber hose and hose clamp it? :confused:
Or cut off the nipple off the coolant crossover and weld and flat plate on it. But I would just bolt it closed. Unless they make a cap that small like what people block there pcv nipple with on the airbox. One of those clamped to the crossover pipe would look nicer if it would hold.
Sent from my PC36100 using Tapatalk
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
x2, I pulled mine off and welded it shut. Ran a rubber cap for a long time though.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Gotcha. I got it now. I'll just go ahead and order the screw in cap from Tony, then put a bolt in the line for now.
Thanks!
jheyob
305
Okeana OH/West Lafayette IN
Edit: not pimping this at all lol but this is what's on my truck.
