Allison 6sp: When resetting TAPS using DVT -- Which option?!?!
Jasondt2001
May 3, 2008
373
Salinas, Ca
OK, using the flash scan today and BBL V8 - I picked (among other things)
The FastLRN1 option to see what was going on.
V2 fastlearn option listing said:
FASTLRN1 [4] FastLearn Information 1
PROGRESS Fast Learn Progress ()
PLANTASS Plant Assembly ()
C5VMODE C5 Volume Mode ()
ADAPTRST Adaptive Reset ()
TOOLMSG Tool Message ()
BSOLPRSL B Solenoid Pressure (NotLearn,Learned)
ASOLPRSL A Solenoid Pressure (NotLearn,Learned)
C5VOLL C5 Volume (NotLearn,Learned)
C4VOLL C4 Volume (NotLearn,Learned)
C3VOLL C3 Volume (NotLearn,Learned)
C2VOLL C2 Volume (NotLearn,Learned)
C1VOLL C1 Volume (NotLearn,Learned)
C1VOLC C1 Volume (NotCnvrg,Convrged)
C2VOLC C2 Volume (NotCnvrg,Convrged)
C3VOLC C3 Volume (NotCnvrg,Convrged)
C4VOLC C4 Volume (NotCnvrg,Convrged)
C5VOLC C5 Volume (NotCnvrg,Convrged)
ASOLPRSC A Solenoid Pressure (NotCnvrg,Convrged)
BSOLPRSC B Solenoid Pressure (NotCnvrg,Convrged)
SUMPTEMP Sump Temperature (°C)
I went ahead and loaded a different tune in the truck, and wanted to reset the TAPS...
I should have asked this ALONG time ago... but, what option do I select to reset them?
I chose at first the first one "Clear All Adapts to Fast (instant) and drove around trying to get it to learn...for quite a while.
It however did not, the progress never went over 0 and it said "not learned" on all the options the whole time.
I then pulled it over, and seeing that it had not learned I thought I did something wrong...:confused:
I then hit ALL the top buttons... (when in doubt, push stuff! :hug:)
I set "Clear All Adapts to Fast (Instant)" and "Clear All Adapts to Fast + Base (instant), "Clear All garage Shift Adapts to Fast + Base" and "preset all TAP Cells"....
I then drove even LONGER, going through the gears, at different throttle positions and even went on a long back road at varying speeds and it STILL says progress 0 and "Not Learned" on all the options...
My questions:
1. How long does it take to learn this stuff?
2. Next time... If i just want to reset the taps, what option do I use? what to the other one's do??
Thanks guys!
slowlmm
Mar 2, 2008
2,582
46
so cal
reset the first 3 top buttons from left to rt then unselect and use the 4th button on top far rt
