wheel bearing failure
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
I've had wheel bearings fail before on all my gmt-800 trucks. Not that big of a deal, 30 minutes to replace and they don't cost an arm and a leg.
I lost a passenger side wheel bearing 3 weeks ago, it started to squeal and I noticed a faint vibration. Got the truck in the air, found play in the wheel back and forth,so I bought a new one. Checked the ball joints on both sides and the bearing on the driver side as well, in case something else was loose. Dr side bearing had NO play. It was the original bearing, it had 122,xxx miles on it. Passenger side was on the second one, first being done at 101,xxx, second at 122,xxx.
This last weekend, I hit the road, going out of town, barely made it 5 miles on the freeway when I heard a loud bang and then lots of thumping, all of this with me at 80-85 mph. This truck sits on 38's so things get amplified a little more with suspension problems. I started making my way to the right shoulder, noticed I had hardly any response from my steering. Finally got onto the shoulder, went to hit the brakes, pedal drops nearly to the floor.
Needles to say, I get the tow, put the truck in the air, found this on the drivers side.
I've never seen one fail this way,and it could get kinda sketchy, especially on a big lift/tires. If this had been a 2wd, I coulda been watching my wheel wander away from the truck on the freeway. Only thing holding it on was the nut and washer on the CV shaft. Rotor tipped into the caliper and ground into it about 1/4" on each end.
Needless to say, check your bearings. This one gave me no indication it was gonna fail, it just snapped. Glad it happened in town and not 2 hours up the mountain though:D
5,835
yikes! i worked on an 03 dodge not long ago that they drove it till the beaing locked up and snaped the stub shaft off along with the wheel, rotor, and caliper with it. destroyed the steering knuckle, caliper bracket and everything out to the wheel with it. you lucked out Wes. dropping a spindle into the asphault after loosing a 38" tire would have been bad news for the truck
whitetrash21
Apr 29, 2008
4,929
Vegas
Weird part was no indication. No squeal, grinding, vibration.... nothing. Just "bang" and it was done.
After I saw the damage, that was all I could think... thank god it was 4wd.... only thing that saved my ass.
Harbin_22
3,858
Southern Indiana
Just did a bearing on a 01 dodge that looked like that. They had no idea until someone told them the tire was leaning. Caliper bracket was the only thing holding thing together
darkness
1,317
380
vegas
your pass. side went out 3 weeks ago, how much more indication do you need? always do wheel bearings in pairs :thumb: :hug:
whitetrash21
Apr 29, 2008
4,929
Vegas
Lift+Bear=bad wheel bearings:D:hug:
Lol.
Not sure where it started. Upper control arm bolt was loose, allowing the camber/castor cam to move. Not sure if thats what killed the bearings or not. Gonna rip the alignment shop a new one though. They left that loose and the outer tierods loose in the spindle. Nothing more aggravating than a shop that don't know what the f*** they're doing.
5,835
Why? My first one was shot at 90k. Next one never went till 160k. Have 168k and they are still tight
as day one
Im scared of Wes period :eek::D
Your scared of wes's period? You callin him a vagina? Ooooohhhh wes i think brian is callin you out for a fight!!! Lmao!!!
whitetrash21
Apr 29, 2008
4,929
Vegas
Wes is a faggot!! I ain't scurred of it! His shit broke cuz it's a lly! Period!
Lbz eatin lly. Broke an all .....bring it, sparky:rofl:
as day one
First time ive had this issue, seems it was caused by something else....
Been called a vagina before.... there was "words" :D
Well his truck is red... :hug:
Lol. Not sure what else to say....:bananallama::D
