What's the word back East?
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
Since the pulling season is winding down here, I'm already thinking 2014. Here in the "Sand Box" every D-Max truck I know of that pulls, has an auto. I'm thinking I want to get away from the auto. What's being used and working in 3.0 back East? I'm also thinking about swapping sides with the spring perches, and running them inboard to tuck DRW's in as far as possible. I looked into it pretty quick, and it looks like it should work with minor tweeks to the frame.
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
Here we can be solid suspension, but iirc the factory suspension still needs to be in place. About how much does the drop box reverser setup run, I've never priced it out or looked into it.
bubba2400
Jul 19, 2009
199
Union Grove, WI
The Zero Drag Reverser, Transfer case, 3 sets of quick change gears, Solid Driveline hookup & Shielding.
The Package is $6450.00.
That's an email I got from SCS a few months ago. Will be the best setup in the long run.
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
That's not bad, i could make most of that selling my current trans and drivelines. what all else would be needed to make it turn key and not be scrounging parts. I'm not firmiliar with this setup, so it's a new area for me.
bubba2400
Jul 19, 2009
199
Union Grove, WI
A clutch, bellhousing, hydraulics or linkage for clutch, mount for drop box, rear engine mount/reverser mount fab'd, drive shafts. Might as well put a big rear axle in it right away too and then gears to match. Not just a bolt in and go conversion. Probably looking 15K for all of it said and done.
bubba2400
Jul 19, 2009
199
Union Grove, WI
Yeah, it snow balls pretty quick. But a ZF6 or NV4500 with cut gears and transfer case may be a better option. Take a look at some of the 2.6 trucks in the midwest and get some ideas. That is probably a little more what you are looking at.
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
Yeah no doubt. We are still about 5-6yrs behind the East when it comes to pulling. I doubt it could ever be like back East, seeing the surface we have to work with.. So kicking it down a notch (or three), the ZF platform having any major issues pulling? & what year/RPO NV should I look for?
ikeG
Oughta Know Better
Apr 19, 2011
2,464
147
Western PA
www.facebook.com
Two of the strongest 2.6 trucks in the nation are running COTPC with ZF6, I believe. They are standard shift, anyhow. Jeremy Goyings and Evan Davis seem like the guys to beat in COTPC this year. Davis is poised to take championship and goyings has won a few pulls with them this year, beating all the Haisley trucks straight up.
If these guys can make a ZF6(if, in fact, that's the trans they are running) last, it should work for you guys.
SmokeShow
6,818
Lawrenceburg, KY
And Jon Swartzentruber (2.6 Hulk Truck) out of the Danville Performance shop is no slouch by any means and has ran a ZF6 for as long as anyone. :thumb:
But why get away from the allison? IMO, until you are over 1000rwhp (on a tight track, probably more on a loose track), the allison can be just as competitive with the proper torque convertor.
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
I agree with the proper setup on a loose track an Allison will be fine.. But trying to lite a big charger and the lock/un lock and any other weird stuff it wants to do is out of my hands to some point. IMO a positive gear and a clutch to control would benifit moreso, but I could be wrong. I'm still new to the big single pulling side, twins And a stock truck was so much easier lol..
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
theres a truck up here in ontario running in the unlimited single class running with wut im told is a zf6, hes makin pretty crazy power.
http://youtu.be/wUyebUmOPW4
That was last year and it was nothing but a problem that's why he went drop box and reverser. Personally if your tracks are loose and your truck is working well I'd stick with the Allison. I actually think the Allison might be an advantage on the really loose tracks but that just my opinion.
duramatt05
Nov 21, 2010
179
sunderland, Ont
Oh ok. Thanks for clearin that up.
durtymax
Jun 17, 2011
50
Not sure about Jeremy, but Evan is running a zf6.
dieselpro55
Puller
Dec 16, 2008
49
Good luck getting a clutch to last..having issues with the major companies time to switch to custom..keep with the allison if your smart
Sent from my iPhone using Tapatalk - now Free
