What's more important?
Sledheadxp800r
That was only my tow tune
Dec 13, 2010
1,151
CT
Im wondering if it Would it be a good idea to run a girdle or all season billet rear engine plate or are these parts overkill? Would you run one over the other? Im unsure of what its going to make for power when it's all together. What do you guys think It will be capable of powerwise also?
Parts list as of now
Arias Standard bore Forged pistons
Crowers
Head/main/rocker shaft studs
Socal Billet injector holddowns
Socal Billet main caps
Big Socal Cam
.180 wall Pushrods
Ported heads
Socal Valve springs
Socal Super damper
SoCal flexplate
SoCal glow plug deletes
Dual stock lb7 cp3s
100 over injectors
single remote mounted Billet 6 blade S475 w/ race cover for now
Burn Down
Sep 14, 2008
7,092
Boise Idaho
Some say they are needed & some say there not... So flip a coin I guess.
Power should be in the 800-850 range, just a guess.
delong_1
<< my work
Dec 5, 2008
1,282
Arvada, CO
from what i understood is the stock rear cover has some flex and can leak coolant under power but at least for me has never been a problem and seems like less of a problem than cap walk to me.
juddski88
Freedom Diesel
Jul 1, 2008
4,655
120
Chesterfield, Mass.
i say no girdle, just main studs. and I think the rear cover is a good idea, just really really pricey...so i didn't do it. I dont mind little leaks on a competition truck
quadracer37
Mar 31, 2009
547
northern, IL
neither are necessary IMO. dont get to extreme with timing and you wont need to worry about your mains walking-no need for girdle.
ive heard of the rear cover coolant leaking problems but never seen it... in 1000 hp street trucks or 1300hp pull trucks on engine dyno or in the truck.
personally id spend the money on upgraded pumps or lbz pumps. two lb7 pumps wouldnt support my 80 over injectors last year, youll have a heck of a time with 100 overs holding rail.
juddski88
Freedom Diesel
Jul 1, 2008
4,655
120
Chesterfield, Mass.
Thats the retail on a II 150% pump or dodge 220% pump. but These exergy pumps are going on a few high profile pullers this season in place of II or WD pumps
quadracer37
Mar 31, 2009
547
northern, IL
The Exergy pumps should be pretty awesome. They are ran on thier Bosch test bench just like their injectors, they cost a little more than some of the other pump builders out there but your gaurenteed a good tested pump thats going to put out what it's advertised to do.
You can put Lbz regulators on your lb7 pumps and that will help, or you can modify your lb7 regulators to I believe.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Back when I was buying my floor it pump, exergy had started testing there's. I'm sure it will be baddass and work great!
Sent from my PC36100 using Tapatalk
